The following compressed file contains samples for the Python SDK: Samples_for_Python.zip. The following samples are inside the compressed file and can be modified to meet a specific need.
Authentication
The Commcell_login.py script runs CommCell log on and log off operations.
>>> from cvpysdk.commcell import Commcell
>>> commcell = Commcell('$[test.xyz.com]', $[admin]', '$[**********]')
>>> commcell = Commcell('$[test.xyz.com]', '$[admin]')
Please enter the Commcell Password: $[**********]
>>> commcell.logout()
'User logged out'
Editing Subclient Properties
The Sub_props.py script updates subclient properties.
>>> commcell = Commcell('$[test.xyz.com]', $[admin]', '$[password123]')
>>> client = commcell.clients.get('$[test]')
>>> agent = client.agents.get('$[File System]')
>>> backupset = agent.backupsets.get('$[defaultBackupSet]')
>>> subclient = backupset.subclients.get('$[test_sub]')
>>> print(subclient.storage_policy)
test_policy
>>> subclient.storage_policy = '$[vs_sdk_test_policy]'
vs_sdk_test_policy
>>> print(subclient.content)
['C:\\inetpub', 'C:\\ProgramData', 'C:\\Python27', 'C:\\restore_test']
>>> subclient.content = [$['C:\inetpub', 'C:\Python27', 'C:\restore_test']]
['C:\\inetpub', 'C:\\Python27', 'C:\\restore_test']
>>> print(subclient.description)
>>> subclient.description = '$[Test Subclient for Python SDK]'
>>> commcell.logout()
'User logged out'
Polling the Job Status
The Job.py script runs job operations.
>>> job = subclient.backup('$[Full]')
>>> print(job.status)
Running
>>> job.pause()
>>> print(job.status)
Suspend Pending
>>> print(job.status)
Suspended
>>> print(job.pending_reason)
Backup job has been suspended by user admin. Reason:[].<br>Source: test, Process: JobManager
>>> print(job.delay_reason)
>>> print(job.backup_level)
Full
>>> job.finished
False
>>> print(job.job_type)
Backup
>>> print(job.job_id)
745
>>> job.resume()
>>> print(job.status)
Running
>>> job.kill()
>>> print(job.status)
Completed w/ one or more errors
>>> print(job.start_time)
Thu Apr 13 12:24:37 2017
>>> print(job.end_time)
Thu Apr 13 12:28:38 2017
Running Cloud Apps Backup and Restore
The Ca_bkp_rst.py script runs backup, browse, and restore operations on a Cloud Apps agent subclient.
>>> agent = client.agents.get('$[Cloud Apps]')
>>> instance = agent.instances.get('$[GMail-Instance]')
>>> subclient = instance.subclients.get('$[test_sub]')
>>> job = subclient.backup()
>>> print(job.status)
Running
>>> print(job.status)
Completed
>>> paths, details_dict = subclient.browse()
>>> print(paths)
['\\Gmail']
>>> print(details_dict)
{'\\Gmail': ['Gmail', 'Folder', '0B', '01/01/1970 05:30:00']}
>>> paths, details_dict = subclient.browse(paths[0])
>>> print(paths)
['\\Gmail\\jdoe@commvaultga.com']
>>> print(details_dict)
{'\\Gmail\\jdoe@commvaultga.com': ['jdoe@commvaultga.com', 'Folder', '0B', '01/01/1970 05:30:00']}
>>> job = subclient.restore_out_of_place('$[test]', '$[jdoe@commvaultga.com/automation]', ['$[\Gmail\jdoe@commvaultga.com\INBOX]'])
>>> print(job.status)
Running
>>> print(job.status)
Completed
>>> commcell.logout()
'User logged out'
Running File System Backup and Restore
The Fs_bkp_brws_rest.py script runs backup, browse, and restore operations on a File System agent subclient.
>>> print(job.status)
Running
>>> print(job.status)
Completed
>>> print(paths)
['C:']
>>> print(details_dict)
{'C:': ['C:', 'Folder', '980.68 MB', '10/04/2017 12:28:37']}
>>> print(paths)
>>> job = subclient.restore_out_of_place('$[test]', '$[C:\sdk_restore]', [$['C:\inetpub', 'C;\restore_test']])
>>> print(job.status)
Running
>>> print(job.status)
Completed
>>> commcell.logout()
'User logged out'
Associating a Plan with an Entity
The plan_assoc_entity.py script associates a plan with an entity.
>>> from cvpysdk import commcell
>>> commcell = commcell.Commcell("$[test.xyz.com]", "$[admin]", $["******")]
>>> test_plan = commcell.plans.get("$[test_plan_name")
>>> # Associates a plan to a backupset
...backupset.plan = test_plan
>>> # Associates a plan to a subclient
...subclient.plan = test_plan
Schedule Policies
The sch_pol.py script returns a list of schedule policies, a schedule object that is going to change, adds schedule policies associated with a subclient, and removes schedule policies associated with a subclient.
>>>from cvpysdk.policies.schedule_policies import OperationType
>>>commcellobj = Commcell('$[test.xyz.com]', '$[admin]', '$[******]')
>>>print(commcellobj.schedule_policies) #Returns all the schedule policies in the CommCell
>>>sch_pol_obj = commcellobj.schedule_policies.get('testsch1') #Returns a schedule object that is going to change
>>>associations = [{‘$[clientname]’: '$[test]', '$[instancename]': "$[DefaultInstanceName]", appName':"$[File System]",
'backupsetName':"$[defaultBackupSet]" , 'subclientName': "$[test_sub]"}]
>>>sch_pol_obj.update_associations(associations, OperationType.DELETE) #Removes schedule policies associated with a subclient
>>>sch_pol_obj.update_associations(associations, OperationType.INCLUDE)#Adds schedule policies associated with a subclient
Disassociating a Plan from an Entity
The plan_disassoc_entity.py script disassociates a plan from an entity.
>>> test_plan = commcell.plans.get("$[test_plan_name]")
>>> # Dissociates any plan if associated with the backupset
...backupset.plan = None
>>> # Dissociates any plan if associated with the subclient
...subclient.plan = None
Viewing Entity Associations for a Plan
The plan_entities.py script returns a list of entities associated with a plan and a list of plans associated with an entity.
>>> commcell = commcell.Commcell("$[test.xyz.com]", "$[admin]", "$[******]")
>>> # Returns list of entities associated with test_plan
...print(test_plan. associated_entities)
[{'subclientId': 1862, 'applicationId': 33, 'clientName': 'name_of_client, 'displayName': ''name_of_client', 'backupsetId': 1847, 'instanceId': 1, 'clientId': 2, 'subclientName': 'subclient_name1', 'backupsetName': '443', 'instanceName': 'DefaultInstanceName', '_type_': 7, 'appName': 'Windows File System'}, {'subclientId': 219, 'applicationId': 33, 'clientName': ' name_of_client ', 'displayName': 'name_of_client', 'backupsetId': 212, 'instanceId': 1, 'clientId': 20, 'subclientName': 'default', 'backupsetName': 'defaultBackupSet', 'instanceName': 'DefaultInstanceName', '_type_': 7, 'appName': 'Windows File System'}]
>>> agent = client.agents.get('File System')
>>> backupset = agent.backupsets.get('defaultBackupSet')
>>> subclient = backupset.subclients.get('test_sub')
>>> # Returns the plan associated with the backupset
...print(backupset.plan)
'test_plan_name'
>>> # Returns the plan associated with the subclient
...print(subclient.plan)
'test_plan_name'
Viewing Instant Clones
The clones.py script returns a list of instant clones in XML and JSON formats.
You can also use an XML file to perform clone operations (such as view, extend, and delete) using the Command Line Interface. For information about how to run Oracle Agent operations, see Oracle Commvault Command Line.
>>> import requests
>>> import sys
>>> import xml.etree.ElementTree as ET
>>> import base64
>>> user = $[username]
>>> pwd = $[password]
>>> server = $[CommServeName]
>>> service = '$[http://:81/SearchSvc/CVWebService.svc/]'
>>> service = service.replace("<>", server)
>>> loginReq = '<DM2ContentIndexing_CheckCredentialReq username="$[username]" password="$[password]" />'
>>> loginReq = loginReq.replace("$[username]", user)
#encode password in base64 for Python 1 and 2
>>> loginReq = loginReq.replace("<>", base64.b64encode(pwd))
#encode password in base64 for Python 3
>>> pwd = bytes(pwd, encoding='utf8')
>>> pwd = str(base64.b64encode(pwd), encoding='utf-8')
>>> loginReq = loginReq.replace("$[password]", pwd)
#Login request built. Send the request now:
>>> r = requests.post(service + '/Login', data=loginReq)
>>> token = None
#Check response code and check if the response has an attribute "token" set
>>> if r.status_code == 200:
... root = ET.fromstring(r.text)
... if 'token' in root.attrib:
.. token = root.attrib['token']
... print("Login Successful")
... else:
... print("Login Failed")
... sys.exit(0)
... else:
... print("There was an error loggin in")
#Login successful.
#2.To get the clones list in xml format
>>> clonesRes = service + "/databases/clones"
>>> headers = {'Cookie2': token}
>>> r1 = requests.get(clonesRes, headers=headers)
>>> if r1.status_code == 200:
print('Clone list received!')
... else:
print('There was a problem in fetching the clones')
sys.exit(0)
>>> resp = r1.text
>>> print(resp)
#To get specific information of the clones
>>> clones = ET.fromstring(resp)
>>> clonedetails = clones.findall(".//clones")
>>> clonesourcedetails = clones.findall(".//clones/sourceInstance")
>>> clonestatus = clones.findall(".//clones/cloneStatus")
>>> targetinstancedetails = clones.findall(".//clones/targetInstance")
>>> res = {'clones': None}
>>> empres = []
>>> i = 0
>>> while(i< len(clonedetails)):
... tmp = {
... 'sourceInstance': None,
... 'targetInstance': None,
... 'cloneStatus': None
... tmp.update(clonedetails[i].attrib)
... tmp['sourceInstance'] = clonesourcedetails[i]
... tmp['cloneStatus'] = clonestatus[i]
... tmp['targetInstance'] = targetinstancedetails[i]
... tempres.append(tmp)
... i+=1;
>>> res['clones'] = tempres
>>> print(res)
