Running Index Server Load Balancing with the Load Balance Index Servers Workflow (CommCell Console)
You can perform index server load balancing by running the Load Balance Index Servers workflow.
The CommCell includes a default schedule called System created index cache load balancing, which runs automatically each Sunday at midnight. You can modify this default schedule or run it immediately. For more information, see Managing Schedule Policies.
The workflow redistributes indexes across index servers using indexing in a CommCell that share the same data paths. The indexes are moved from overloaded servers to under-utilized servers that can host the indexes.
To determine whether you need to run load balancing on index servers, you can use the Index Server Load Report. The Index Server Load Report displays information about index load statuses, index load trends, and index size distributions across MediaAgents that are acting as index servers in a CommCell.
If the workflow fails, the system will not run it again automatically.
  1. From the CommCell Browser, in Workflows, right-click Load Balance Index Servers, point to All Tasks, and then click Execute.
    The Load Balance Index Servers Options dialog box appears.
  2. From the Run workflow on list, select the workflow engine that you want to perform the workflow.
  3. Select one of the following modes:
    • All Index Servers. This option performs index server load balancing across all index servers that share data paths.
    • Within Storage Policy. This option performs index server load balancing across the index servers that share data paths as defined by a storage policy. After you select this option, the workflow will ask you to select a storage policy.
    • Index Server Selection. This option performs index server load balancing on one available index server. After you select this option, the workflow will ask you to select an index server.
  4. To perform load balancing only on overloaded servers, select Load balance only from overloaded servers.
  5. Click OK.
    Once the job completes, it will take up to 24 hours for changes to be reflected in the Index Server Load Report.
