Index Gateway: System Requirements
Verify that your environment meets the system requirements for Index Gateway.
Operating System
Important
Use the most recent version of the operating system that is listed. The Commvault software fully supports the most recent version of an operating system, until the vendor ends support. More recent versions of the Commvault software might not install on operating systems that are not supported by the vendor anymore. For information about the support lifecycle of an operating system, contact the vendor.
Linux
Operating system
Processor architecture
Red Hat Enterprise Linux 8.2 through 9.5
x64
Rocky Linux 8.9 through 9.5
x64
Windows
Operating system
Microsoft Windows Server 2019 Editions
All Windows-compatible processors are supported
Microsoft Windows Server 2016 Editions
Microsoft Windows Server 2012 Editions
Hard Drive
Component
Space required
Temp folder
20 GB
Internet Information Services
To install this software, Microsoft Internet Information Services (IIS) must be enabled on the computer and meet the following requirements:
  • Internet Information Services Manager version 10.0 (on Windows 2016 only)
  • Internet Information Services Manager version 8.0 or 8.5 (on Windows 2012 only)
Software That Is Automatically Installed
.NET Core
.NET Core 10.0.8 is required and is automatically installed.
DISCLAIMER
