You can configure a subclient to run block-level backups of the Microsoft SQL databases.
After enabling block-level backup on a subclient, the Microsoft SQL Server agent automatically converts to using Indexing Version 2.
From the navigation pane, go to Protect > Databases.
The Overview page appears.
On the Instances tab, click the SQL instance.
The instance page appears.
On the Subclients tab, click the subclient that you want to run block-level backups from.
In the Settings section, move the Optimize for table level restore toggle key to the right.
After enabling block-level backup on a subclient, the next backup operation is always converted to a full backup.
