Remote CommCell Properties - Online Help
General
Use this dialog box to view the registered CommCell® information.
  • Remote CommCell Details
    • CommCell Host Name
      Displays the host name (fully qualified domain name) of the registered CommCell.
    • CommCell Client Name
      Displays the client name of the registered CommCell.
    • CommCell Number
      Displays the CommCell ID number (hexadecimal value).
  • Re-Register CommCell
    Click to re-register the source CommCell with appropriate CommCell name.
  • Check Connectivity
    Click to verify the connectivity and the status (such as available or offline) of the registered CommCell.
Monitored Entities
Use this dialog box to select the appropriate clients, agents, backupsets, or subclients that are on the PodCell for import
  • Reload CommCell Tree
    When clicked, any new clients, agents, backupsets, or subclients available on the PodCell appears.
Client Groups and Prefixes
Use this dialog box to select the client group for imported clients and set prefixes for entities (such as Storage Policy, Schedule Policy, and so on).
Please select the client group to which all imported clients will be associated
  • Use the following client group
    Choose this option to associate all the imported clients to a client group.
    Client group
    Select or enter the client group name in the list.
  • Do not associate to any client group
    Choose this option if you do not want to associate clients to a client group.
Set prefixes
  • Do not prefix imported entities
    Choose this option if you do not want to prefix to imported entities.
  • Use following suffix if local entity of same name already exists
    Choose this option to prefix only those imported entities that have the same name on source CommCell and destination CommCell.
  • Always add the following prefix to imported entities
    Choose this option to always prefix the imported entities.
    • Prefix
      Specify the name for a prefix.
Library Mapping
Use this dialog box to configure MediaAgents on the destination CommCell or edit the destination Mount Paths if required.
  • Source Library
    Displays the Source Library which is being migrated from the PodCell.
  • Destination MediaAgent
    Select the MediaAgent to be associated with the library on the destination CommCell which is currently being imported.
  • Mount Path
    Select the Mount Path of the source library for migration.
  • Location
    Specify the location on a destination MediaAgent that allows you to access the imported Mount Path.
  • Credentials
    Specifies the Username/Password to access the Mount Path if the Mount Path is hosted on a Network location.
  • Prune Allowed
    Select the check box to prune the data on the Mount Path after the migration is complete.
    Contact your Software provider to have this option enabled.
  • Select MediaAgent For Index Restore
    Select the MediaAgent from the destination CommCell.
    Once specified the MediaAgent access the index from the imported library and stores in the index cache folder. This is useful for restore operation.
  • Edit Location
    Click to specify the location to access the imported library.
    Edit Location is highlighted when a MediaAgent is selected under the Destination MediaAgent column.
    For more information, refer to Restore Data from Imported Clients.
Push Back
Use this dialog box to push the CommCell configuration settings from the destination CommCell to the PodCell.
  • Pushback Configuration
    Select this check box to push the CommCell configuration setting from the destination CommCell to the PodCell. This allows pushing the Alerts, Schedule Policies, and other configuration created at destination CommCell to the PodCell.
Schedule Pattern
Use this dialog box to setup the monitor schedule.
  • Schedule Name
    Type a name for the schedule in the Schedule Name box.
  • Start Time
    Specify the schedule start time.
  • Every
    Select the number of days for which you want to run the job repeatedly.
  • Exceptions
    Click to define weekday occurrences or days of the month which you want to exclude from the schedule.
  • Repeat Every
    Select the check box to repeat the schedule, select the check box.
    Select the values for hr(s), min(s), until
    Click one of the following Daily, Weekly, Monthly, Yearly.
