Enabling Block-Level Backups for SQL Databases from the Command Center
You can configure a subclient to run block-level backups of the Microsoft SQL databases.
After enabling block-level backup on a subclient, the Microsoft SQL Server agent automatically converts to using Indexing Version 2.
  1. From the navigation pane, click Protect > Databases > Instance > Subclient.
    The subclient page appears.
  2. In the Settings section, move the Optimize for table level restore toggle key to the right.
After enabling block-level backup on a subclient, the next backup operation is always converted to a full backup.
Block-Level Backups
