Required outbound connections for Air Gap Protect storage
To communicate with your storage, Air Gap Protect requires that certain endpoints (URLs) be opened.
  • Replace [region] with the region the MediaAgent is in.
  • If your environment requires an HTTP proxy for outbound internet access, configure the proxy.
Source Destination TCP/UDP Port Commvault SaaS Commvault software
Control plane https://login.microsoftonline.com TCP 443 -- Yes
Control plane https://api.mcss.metallic.io (40.75.17.108) TCP 443 -- Yes
Control plane https://metallic.io TCP 443 -- Yes
Control plane https://www.commvault.com TCP 443 -- Yes
MediaAgent s3.[region].amazonaws.com TCP 443 Yes Yes
MediaAgent s3.us-gov-east-1.amazonaws.com TCP 443 Yes Yes
MediaAgent s3.us-gov-west-1.amazonaws.com TCP 443 Yes Yes
Azure global regions
MediaAgent *.blob.core.windows.net TCP 443 Yes Yes
MediaAgent https://login.microsoftonline.com TCP 443 Yes Yes
Azure Government regions
MediaAgent *.blob.core.usgovcloudapi.net TCP 443 Yes Yes
MediaAgent https://login.microsoftonline.us TCP 443 Yes Yes
MediaAgent storage.googleapis.com TCP 443 Yes Yes
MediaAgent https://www.googleapis.com TCP 443 Yes Yes
MediaAgent objectstorage.[region].oraclecloud.com TCP 443 Yes Yes
MediaAgent identity.[region].oraclecloud.com TCP 443 Yes Yes
